Exquisitely-machined T16R Cu. 380 Lumens Keychain Flashlight
Limited Copper Edition
Features:
● CREE XM-L2 U3 LED, with a lifetime of up to 50,000 hours;
● Slightly depress the side switch to turn on/off the flashlight as well as selecting desired output mode:
Turbo (380 lumens, automatically lowers to High after 3 mins continuous use)
High (180 lumens, 2 hrs )
Mid (50 lumens, 10 hrs )
Low (10 lumens, 60 hrs )
Strobe
● Constant current circuit, constant output
● Uses one single CR123A(16340) battery
● Working voltage: 2.8~4.2V
● Convex lens with as high as 95% light transmittance
● Dimensions: 59mm (length) x 26mm (head diameter) x24mm (tail diameter)
● Weight: 30.8g (battery excluded)
● Quality copper; Stainless Steel retaining ring on the top
● Anti-oxidation finish
● Waterproof, in accordance with IPX-8 standard
● Accessories: Lanyard, O-rings
Features:
Strobe
