sunwayman t60CS not working on internal carrier with batteries
lightliker
Hi All,
Having a 6 year "old" sunwayman t60cs.
Coming back from travel abroad, it doesn't operate at all on the provided carrier filled with 3 x 18650 cells.
Connecting it directly to a car battery, the light switches on and works.
I mesure 12.58Volts on the inner contact of the charging port.
Could this be the fuse, or should I haven't measure a voltage at all?
Thanks for reacting!
thermal guy
ny
If you get 12 something volts with your meter across the battery carrier that sounds right to me. Measure it just like its one big battery.one lead one side one on the other side
lightliker
Hi Thermal guy,
Thanks for reacting.
Dropping a small dot aluminium foil (pellet) in the empty battery enclosure resulted in a working light.
The inner tube must be oxidatet heavily so cleaning it will resolve the problem i hope :)
Kind regards
Lightliker
