Super AAA MiniMag?
Juggernaut
A place in need of light.
What would happen if you put a TLE-20 LED bulb in a AAA MiniMag and then ran it on two 10440 rechargeable 500 mAh, 3.6 volt lithium AAA batteries. The bulb is designed to be a drop in for AAA, AA, and 2-4 D Maglites so it would be running at 7.4 volts instead of it's specified 6 volts. Would it work? How long would it run? Could the bulb take it and for how long? Any help would be appreciated.
That would probably fry the circuit in the drop-in.
Also, that drop-in isn't really bright. For max output, I'd recommend running a current gen LED(Cree XR-E P4-R2 bin, Seoul P4 U-bin, Rebel 80 or 100) in direct drive from one 10440 battery with a good thermal connection from the LED to the body of the light so the LED doesn't fry.
Presuming good batteries, you should be able to get 100+ lumen out the front.
:welcome:
There is no powerful drop-in for the AAA minimag. Just the TLE-10/20.
The TLE-20/10 can only handle about 3 volts or so (2 batteries). The kit says it can handle more cells because the bulb adapter has a small resister soldered into it.
BTW, using the TLE-20 with bulb adapter in a 2 cell light is awful and dim because the resistor drops a bunch of voltage.
I have one. It's decent in a AA/AAA minimag, but sucks for all other applications.
Well, using the TerraLux TLE-10 in a 2-AA Mini-Mag
seems to give about the same light as the standard incand. bulb.
Hope this is of some help.
_
