MWClint
I've been searching for a really low _single level_ light that wasnt a 5mm led.
nada.
In the meantime, the Pacific SP's became my most used lights that I wasnt
EDC'ing. So i thought i'd try a Pacific XLR version.. it's only 50cp on AA. I
beleive it registered ~70ma coming out of the battery. Turned out it was still
brighter than the EX10 on low(~6lumens). pacific xlr eyeballs to be about 13-15 lumens(it's a very useable indoor light as is)
Anyway while adjusting the internal spring screw plug in the keychain body, i
thought of replacing it with a resistor to limit the current. there's plenty of space in the keychain bodies.
a 10ohm 1/4 watt resistor worked perfectly. wound one lead around the body
of the resistor and pushed it snugly inside the brass plug and twisted the other lead into a spring shape. screwed it back into the body.
so now i have a single level Seoul P4 "SDDL" (super duper dim low). :naughty:
current doesnt even register on my meter..i wonder how long a fresh eneloop will last at this level.
The light...
Left: EX10 on low+rcr Right: original Pacific XLR
Left: EX10 on low+rcr Right:10ohm modded Pacific XLR
Closeup of the resistored Pacific's beam.. flawless!
the mod: pulled spring out of brass plug and replaced with coiled up resistor.
Nice tight fit, dont even need to solder.
compared to an HP Matterhorn. :twothumbs
With the 2 levels of threads in the tail of the body, it would be really
easy to fit a logarithmic pot and a knob back there for an infinitly adjustable
light. might have to order another peak!
My search for a low light is complete. i can sleep easy now.
nada.
The light...
