Jarl
I'm looking for something capable of supporting 12V, 18A. Must be relatively small, low self discharge, long service life and good temperature tolerance, and stable! Capacity, if it lasts 2 minutes at that current draw it's more than enough, 30 seconds will be adequate. (300mah?)
Less cells the better, though I expect to need more than one.
I'd like to say cost not an issue, but lets cap it at about $30 for a single set of cells.
Idea's? The only plan I have is to run 3 LiMN 16340's ridiculously over spec and throw them out after a few runs.... The 26500's could handle it, but I couldn't justify the outlay considering how little use they'll get (once, twice a year?)- size is also an issue.
