DarkLight Enlightened Joined Jan 13, 2005 Messages 538 Location Elkhart,IN Feb 11, 2005 #1 I just picked one up on Ebay for about 70 bux two years old rarely used.. Good deal or did I get hornswoggled?
DarkLight Enlightened Joined Jan 13, 2005 Messages 538 Location Elkhart,IN Feb 14, 2005 #2 lol @ the number of views vs answers... anyways.....I just got the darn thing but have no idea at what rate I should be charging /discharging my mag 85 pack.. when I set it to discharge at over 1.2a it kicks out on overload protection... then cycles back on till it kicks out again... normal? I have it set to charge at 1.0 amps right now for the pack... 9x2300mah batts......any experts out there with some tips?
SilverFox Flashaholic Joined Jan 19, 2003 Messages 12,449 Location Bellingham WA Feb 14, 2005 #3 Hello DarkLight, Need more information. What choices do you have to choose from? Tom
DarkLight Enlightened Joined Jan 13, 2005 Messages 538 Location Elkhart,IN Feb 14, 2005 #4 choices are battery type, number of cells, and charge/ discharge amperage. you program it manually according to the size of your pack. Its just the charge rate itself is completely left up to the user... 0 to 5 amps....
SilverFox Flashaholic Joined Jan 19, 2003 Messages 12,449 Location Bellingham WA Feb 15, 2005 #5 Hello DarkLight, I am concerned that something might be wrong with your power supply. When it trips out at the 1.2 amp charging rate, what do you read for Vi? What are you using for a power supply? A 1 amp charge rate should be fine for 2.3 Ah cells. Tom
DarkLight Enlightened Joined Jan 13, 2005 Messages 538 Location Elkhart,IN Feb 15, 2005 #6 charges fine its kicking out on PACK DISCHARGE..... I am using a 18ah 12v sla for power, fresh from the trickle.. Charges just fine...just on the discharge cycle its generating too much heat... I guess.
DarkLight Enlightened Joined Jan 13, 2005 Messages 538 Location Elkhart,IN May 25, 2006 #7 btw fox I fixed the problem an output transistor was not heat sinked right and burned up, I replace it and all is well!
SilverFox Flashaholic Joined Jan 19, 2003 Messages 12,449 Location Bellingham WA May 25, 2006 #8 Hello DarkLight, It sounds like it is capable of around 14 watts of discharge capability. If you exceed (or sometimes come close) to that, it shuts down. Tom
