surefire 6pled ?
madi05
carolinas
is it ok to use aw rcr123 with this led ? also will the runtime be good or will it be better using that 17___ one i read about ,, i have looked alot and everything is so confusing on this light ,, TMI basiclaly , lol
i know if i dont like the p60L stock to get me a makoff ,, lol
also what is the best tailcap that makes it tailstand and looks like the light cosmetically and can make me change modes low med high strobe whatever ,else
thanks alot for taking the time to either show me the threads that support this or ssimply just answering it
madi05
madi05
You can run it on 2 AW 3.7v cells. DO NOT put an extender on it and run it on 3 AW 3.7v cells. You will fry it.
thanks so much ,, i want to keep it as stock if possible ,, and i was thinking the rechargeables would be brighter than the regular cr123 ,, but for some strange reason i just couldnt find a post saying it was ok , lol
now i have to find me a tailstand switcch that matches fairly well , lol
madi05
You should get somewhat less output on a single 17670 but considerably more runtime. I'd try that, I'm not a big fan of rcr123 capacities.
madi05
Just saw your newer post...
The module regulates down to ~4v or so, so you'll get the same outputs from 2x3.7v and 2x3.0v. The buck regulator won't have to do any work with 1x3.7 (17670), so although it won't be quite so bright, it will be a slightly more efficient configuration, and the capacity of 1x17670 is definitely more that 2xRCR123.
so could i bore out my body and get even more runtime on a 1 X 18650 and more output? also will any of these configurations hurt my p60L?
also how can i make it where i can switch modes ? like a low low maybe a med. and a high
thanks
madi05
thanks
madi05
Check out AW's thread on the soft start 3 level tailcap switch mod for Surefire C series lights like yours. Has low, med, high, and allows regulation at all three outputs.
Bill
HI, i looked at aw offers on cpfm and couldnt find what u are referring to ,, can u direct me please ? also does it match pretty good ,, this sounds like what i want ,, lmk
thanks
madi05
