Pellidon
Picked up a second gen (320 lumen) 6PX Pro that will now only run on low mode. It did run on low or high. Is it fixable or is it now a nightstand light?
Help Support Candle Power Flashlight Forum
What battery/cell are you using?Picked up a second gen (320 lumen) 6PX Pro that will now only run on low mode. It did run on low or high. Is it fixable or is it now a nightstand light?
I was using 2 cr123'S and a 16750. I have it unplugged to see if it resets.What battery/cell are you using?
I have noticed that a bunch of my stock 2×cr123 surefires do not like single Li Ion cells...my EB2 hates them, but my G2X pro tolerates them. The EB2 would only come on low while a Liion was in there, after a bright flash...I thought I had killed it, because even 2×cr123a did not reach max brightness until I let it sit for a while. It is now functioning as normal, I hope the same method works for you.I was using 2 cr123'S and a 16750. I have it unplugged to see if it resets.
That is strange. I've never heard of a light being temporarily damaged and then fixing itself. Not if it's not due to water ingress.I have noticed that a bunch of my stock 2×cr123 surefires do not like single Li Ion cells...my EB2 hates them, but my G2X pro tolerates them. The EB2 would only come on low while a Liion was in there, after a bright flash...I thought I had killed it, because even 2×cr123a did not reach max brightness until I let it sit for a while. It is now functioning as normal, I hope the same method works for you.
That's what I mean. It's not even resetting. Not really. It's just low cells can't support high output. Fresh cells can.If the voltage drops too low, the light has a power save mode that sets it to low only. Fresh batteries should reset this. Not this time. It goes back to be evaluated.
