I bought a used SureFire 8X this past weekend, and it had two batteries with it. When I charged up the first one, I was all set for the flashlight to knock my socks off, like the 9Z did when I put $18
worth of Lithium 123As in it. However, the tailcap was hard to push far enough to get light, the light that came out was feeble, and even completely tightening the head didn't guarantee that I would get any light out of the business end, let alone the bright light that occasionally came out.
Obviously disappointed, I figured I had nothing to lose, so I ran the first battery down and popped the second one in. Voila! Suddenly, everything worked as I expected!
I looked at the two batteries, and the only difference I could see was at the positive end of the battery. On the battery that made everything work as expected, the raised center portion (that looks like a 9V battery contact) is surrounded by a metal ring, then a very thin "moat", a similarly thin "moat wall" of black plastic, and then an outer metal ring. On the battery that didn't work well, everything looks the same except that the center portion is surrounded by black plastic out to the radius of the outer "moat wall" on the other battery.
Any ideas, anyone?
Any ideas, anyone?
