Hi guys, I have finally finished my little project here.
I made a fiber tube so the 2xIMR 18650 wouldn't rattle and I changed the 2 lamps into 9V lamps. Now I have an incan 9V high/low beam torch that uses the new IMR cells, sweet.
For the low lamp, I used a ES-9, 0.85A lamp. I frosted the whole thing, but that was probably a mistake since it couldn't focus anyways. Pretty easy to take the lamp out from the grey glue.
The high lamp is a new 9V lamp made for 2xIMR cells. It was a PITA to take out, the entire thing was sealed with white powdered glue. I didn't frost any part of this main lamp.
We use the same grey glue and white glue, so I basically assembled it back the way it was done.
It turned out really great and it was pretty darn bright!
I will compare with a EO-9L on Monday, probably kills it. :laughing:
The low beam wouldn't focus at all, so there is a large dark ring in the center when it was switched to low. Basically the same beam as the stock low lamp, but at least it is a bit brighter. Good for maybe reading a book or a sign or something at close range.
I will try a lens-end approach when I have the time, it needs to be specially made, so I will just wait until I am really bored.
I don't know how to take beamshots, I have failed numerous times at it.
But I will take some photos of the assembly for you guys to see when I get back on Monday.
Note: This is just my own little project as a hobbyist because I fried my lamp and was too cheap to buy a new one.
Please do not ask me to do it for you. This has nothing to do with my company and
no it will not be made as a product.
PS. The tube is removable so I can just buy a new SF 3.6V lamp assembly and it will be a stock 9AN all over again. No irreversible mod here, it was my Father's Birthday present that I gave to him a few years back, so I don't want no trouble.
Cheers,
Mark
