etc
I want to be able to use SureFire 9P with the Malkoff M30 module, which I understand is designed for 3V versus higher 9V of Surefire 9P.
I also want the flexibility of using 2xAA, whether Lithiums L91 or NiMH or 2x18500 in the same lite if it gets bored out.
Question, I assume I won't be able to use 123A cells in the same lite with the M30 module? Because 3x123A will generate too high a voltage?
If so, that would be OK as long as I could use 2xAA cells or 2x18500 cells. Any other options with the M30 module?
How many lumens am I am looking at?
