Re: surefire A3 Avaiator
[ QUOTE ]
cheapo said:
whatever, I know plenty about flashlights, but I know that if I want 50 lumens I would get L4. It has better runtime. I dont get it, why the heck would you buy A2 over L4. Well, I would go with L2, or L4.
-David
[/ QUOTE ]
I do not own an A2 but I did get to play with one at a SureFire dealer and I do own an L4 (actually, an E2e + KL4 which is the same as an L4 but w/o the Z57 clicky switch - still need to get a McE2s) and I can think of a few instances wherein an A2 would prove superior to an L4.
First, in some situations, the 65 lumens of the L4 is overkill. It is too bright. The L4 does not provide two-stage / lower-level output functionality out of the box. The A2 does. This is not good for situations such as close-up work, a situation where you are trying to preserve dark adapted vision (the classic example is that of a pilot in a cockpit) or if, say, you wanted something a wee bit discreet (for example, you are a parent wanting to just check up on the kids without waking them up). The low-level LED mode of the A2 would be a boon in situations such as those.
Another possible advantage of the A2 is that incandescents tend to do better than LEDs in fog or rain so if you expect to have to deal with those, I believe an A2 would edge-out the L4. The incandescent beam tends to cut through the moisture better. The flood of light that an L4 produces would tend to refract back at you.
And as far as runtime is concerned, the low-level mode of the A2 has better runtime than the L4.
Bottom line, while I love my L4 I think the A2 is more versatile in that it allows the user the choice of using the low-level LED or the high-level incandescent as the situation demands it. You do not have that versatility in an L4.
Just my 2 cents.
