I just achieved my very first bore tasks. Recently sent two 6P bodies to my local precision parts/machining facility for 18mm boring. Have asked the tech to stick to ~18.7mm (also Fivemega's standard bore spec) as discussed during our last meetup some months back (they told me the minimum tube thickness would be around 0.5mm which should be still safe to use on everyday basis without accidental drop etc.). The bodies came back to be in excellent condition and the bore is indeed tightly controlled at the 18.7mm range (eg. 18.69mm).
I foresee myself sending more 6P bodies for such process soon. Now my question is, should I go further and look into 18.9mm boring instead, for more protected 18650 compatibility? Will that be more risky and more prone to failure (or mishaps) during the machining process? And will that further weaken the body's tailside threads to a more dangerous level? And will a 18.9mm bore increase resale value (of the body concerned)?
Feedback appreciated......
