Help Support Candle Power Flashlight Forum
If you scroll fast enough you can see all the parts from that original light, E1B body and E1B head and tail from my post. 🙂View attachment 36248
One of my favorites. Malkoff tricap, E1B body, Malkoff neutral 3 mode MDC head SST20 4000k 95CRI
Curious how Surefire E1 heads will handle 18350 or 18500 batteries, will it fry the head eventually or cause battery problems? Really liking an SF E1B head I have with a fivemega 18350 body.....
Yes, I should have specified newer E1B MV Backup head, I do have a few of the LF heads as well, like them a lot. Thanks!![]()
This is an E1. Incan. Any secondary Li-ion would fry the MN01 lamp. I'm not certain the E1e is identical inside, but it's also incan and came with an MN01. Lumens Factory makes other lamps for E that take Li-ion, and so did Tad Customs before withdrawing. E1L and E1B are LED, and iirc they're also primary 3V only. Mark @ LumensFactory also sells replicas of 3 types of the LED heads Surefire once made, I believe with various color temperatures available, some with modes, and they will accept primary or secondary Li-ion, one or two cell heads available. Check out the one with fins (KL1 replica).
The newer E1B MV will handle 3.7v li-ion 16340 and other sized 3.7v batteries. I’ve tested this and no change in brightness from LED. I had also emailed Surefire and had asked if it can handle the voltage and they said yes. The E1D, E1B, EB1, and newer one cell lights are secretly duel fuel, they don’t actually specify it because they market their lights as dependable and make money off their CR123s.Yes, I should have specified newer E1B MV Backup head, I do have a few of the LF heads as well, like them a lot. Thanks!
Thank you, one of these days I need to talk you into a picture of a MDC Bodyguard V2 head on a E1 body if you have that, which I am guessing you do. 🤣The newer E1B MV will handle 3.7v li-ion 16340 and other sized 3.7v batteries. I’ve tested this and no change in brightness from LED. I had also emailed Surefire and had asked if it can handle the voltage and they said yes. The E1D, E1B, EB1, and newer one cell lights are secretly duel fuel, they don’t actually specify it because they market their lights as dependable and make money off their CR123s.
Thanks, I had seen that post on Reddit when looking up the head. It’s pretty big and plenty of light for sure. I wish it was available with a crenelated bezel.I used to have that head, not anymore. It would look like this without the SS crenelated bezel, one of my favorite Lego combos. Here is my post of the bodyguard V2 beamshot HereView attachment 36425View attachment 36426
1125 Lumens (Output), HA3 Black, Cren. Bezel, single-mode "Tactician" on Surefire E2D body.
I take your comment as a compliment 😉I'm very sorry, DAN92, your E is just too darn bright. Please stop pointing that thing westward, you're keeping us awake.
Yes if it has the first 3 letters of KE1 it can safely run an RCR123 3.7v.E1D uses KE1D-A head - unless you meant just first three characters? E1L-A uses KE1.
I have never heard of SF confirming that rcr123 can be used in any of cr123 lights 🙂
