Modern_Major_General
- Joined
- Jul 27, 2006
- Messages
- 140
What kind of Cree emitter do these lights use? P4? Q2? Q5? Thanks!
I think that Surefire is using the best of best, at least Q5's, now.
Bill
That's speculation. Nobody knows for sure.
I would like to know that too...
And I would know, please, if they use the exactly same head ? (Size, TIR, capacity of throw, etc)
They use the same TIR so you end up with the same beam profile in all the newer Surefire E heads (E1B, KX1, KX2, E2DL head). The only difference is how much light comes out and which will run off rechargeables.
Using regular batteries only: KX1, E1B
Using rechargeable RCR123 3.7 v (one or two): KX2, E2DL head
The KX1 & KX2 heads are low first, then high.
The E1B & E2DL heads are high first, then low.
