Two E2E-HA's bought together a week ago, the boxes are identical:
Is this a tolerance issue? >2mm longer seems a bit much...
There's a visible gap between the front part and the main head part in the longer one, and the lamp assembly is stuck, but it could probably be removed with force. The longer one had the Z52 rotary switch, which might indicate that it is the older version. Both have the newest body with 3 rounded sides. The longer one has a more focused beam with a brighter hotspot:
