Surefire G2 LED vs. Fenix L2D Q5
bender29
I've decided I want to get a higher quality flashlight, I think I'm now hooked. I'm going to move up a level and have been looking at both of these models. They are around the same price and both seem great. The biggest positive for the Fenix is that it runs on AA's. Which would you choose between these?
Also how do either of these compare to the Task Force 3w CREE I just purchased? I'm sure the biggest difference is build quality, but regarding the actual beam?
Thank you!
And what is the biggest positive for the G2..:thinking: maybe the name and its made in USA:crackup:
Both are great lights, if I had to choose, I would take the Fenix any day.
Personally, the fenix. The L2D is a really nice, good quality variable level light, and though single/dual level lights do have a nice, rugged simplicity, being able to choose the near exact level is really nice.
I don't own the Fenix L2D Q5, and I've never held it. I cannot provide an objective opinion on this.
But in your heart of hearts, I suspect you already know that the SureFire is the better of the two lights. :)
There are certainly reasons to purchase a Fenix over a SureFire. The Fenix being in the same league as the SureFire is not one of those reasons.
No one light is for every task. ;) Is surefire better than fenix?... ...We may never know... :candle:
Both are quality flashlights and meet their advertised specifications. I hope this doesn't turn into another Surefire vs. Fenix thread.
My $0.02: consider the Fenix L2T v2.0 - no strobe/SOS.
I was looking at the L2T since it was $15 cheaper. It looked relatively similar to the L2D. The L2D seems to have just a bit more power though.
Fwd clickie vs reverse clickie. AA vs CR123, plastic versus metal. Vastly different lights.
If you've never had the L2D Q5 it is one amazing light. Completely different from the G2.
I'd pick the Fenix L2D-CE Q5 for AA powered(I'd suggest rechargeable batteries), multimode, brighter, and the ability to accept the P2D(1 CR123) and L1D body(1 AA).
The G2L is good too, it might be the better choice depending on what you'll use the light for.
Hey, well done. You've added nothing positive to this thread, have decided that the G2L is better than the fenix despite not knowing what it'll get used for, and probably made the thread into a fenix vs surefire flamefest. Could you drown in your ignorance sometime today please?
My E01 is better than an HID. Yes really.
I'd say pick based on battery and/or size preference. If your making the choice for your primary light and you've already stockpiled a ton of AAs, I think the Fenix would be a no-brainer. If you prefer the shorter and thicker 123a form factor, get the surefire. They aren't really two lights you can just line up and compare, so make your choice based on your personal convenience.
Honestly I have owned both lights....
Here is my take....I kept the surefire g2l....the fenix is a great light and does what it was intended to do well, i.e. have multi modes run on AA batteries, short-short/medium distance light,decent beam pattern, strobe and blah blah blah...
I kept the g2l for these reasons....the same light every time (no fumbling through UI), the cr123a form factor (slightly thicker/shorter), the availability of surefire parts and acc. in my area, carry and mounting options, beautiful beam pattern....
the last deciding factor that went into wich light for me was that i have had a fenix L series light fail on me, and have yet to have a surefire fail on me yet.....I am not trying to say that fenix is a lessor company just that in my personal exp/opin I went the way I did
All in all the final decision is up to you....All these pick for me threads boil down to the same answer(and quite frankly the frequency/redundancy of these threads is boggling)....you need to pick the light YOU like best and run with it, after all YOU will be the one using/feeding/carrying it.... you will be pleased with either, in actuallity they are both good lights and have thier places in every flashoholics lineup
Well, as others have noted, these two lights are VERY different beasts. And which one you ought to choose would totally depend on what your intended use(s) is/are. To me, it's not even something that should stoop to the level of Fenix vs. SureFire, because the two lights aren't even functionally comparable (like comparing apples and oranges).
Anyway, I'd say the G2L is a light that I would throw in my toolbox, or stash somewhere in the house for emergency purposes, or use as a car light, etc. For me, for example, it has replaced my use of the Mag 3D (except in cases where I actually want a huge club, or where I need the extra throw). The G2L is not, however, a comfortable one to have in your pocket all the time. Also, the Nitrolon body could be much more pleasant if you think you'll have to use the light frequently in the cold.
The L2D is definitely a much more pocketable light. This is the one that I would choose if I were looking for a light to carry on my person on a daily basis. Since it takes AA's, and since most AA's that one would have access to are alkalines, it's not a light that I would want to store as an emergency light, car light, etc., where you never know what extreme temperatures it might have to be used in, or where it would go for very long periods with no use. But of course, if you're using it everyday, and thus likely changing out the batteries on a somewhat regular basis, then its use of AA's could certainly be an advantage. Of course, perhaps the biggest plus to the L2D is that it has multiple modes, so for most EDC purposes, I'd say that's a huge advantage over the G2L.
Bottom line: consider what you intend to use the light for. I trust CR123 lights a lot more than I trust AA ones, but that's because I don't necessarily know how long my cells will sit around before I use them, and I've had infrequently-used AA lights that pooped out on me at times when it would have been really handy to have a light. But that really depends on your own use of the light and cells.
Of course, you could do the good flashaholic thing and get both. After all, it never hurts to have backup.
You can upgrade the LED module with a stronger one from a variety of aftermarket lamps. (Malkoff, BugOutGear, Wolf-Eyes, or Lighthound Cree Q5 LED drop-ins. Along with the Solarforce R2 drop-in that might be the brightest bang-for-the-buck out there).
A Novatac clip and a thick 5/8-inch O-ring turns the G2L into a bezel-down clip-carried light. Messing around with a holster can be a pain at times. Some folks also prefer a momentary tailcap switch.
I'd go with the G2L, unless battery cost is an issue or someone specifically wants a AA light.
