Surefire G2 with Lighthound Cree Drop-in
ADDICTED2LITE
arkansas
Ah, NO!!:awman:
I actually got it to work by modifying the spring to get the negative contact. After two minutes of running the outside of the light felt fine, cool even, BUT, I took the bezel off and almost burned my hand on the LED module, this thing gets way too hot. So, operating in a G2, yes, lasting more than 5 minutes in a G2, no.
zx7dave
Seattle
You can use aluminum foil to wrap around the LED base and will help it make contact in the G2/G3 models. I ran my G2 with Cree P4 for 30 minutes. Hot? Yes. But G2 was undamaged after it was all over. It is a tough light.
Elton
Oregon
geez im not sure which led bulb to get i thought they where supposed to run cooler ?
jlomein
Vancouver, Canada
What kind of batteries were you using?
I have ordered a cree drop in for the G2 and I will be using 2x 3.7v 750mah AW protected RCR123's. I'm rather worried about the batteries getting hot, since there is a metal lining inside the nitrolon battery tube, and I assume that's where the heat will go.
