I couldn't seem to locate this in the search function.
I recently purchased a Surefire 6P and replaced the P60 with a Malkoff M30W. I am operateing this with 2 AA batteries. The light functions perfectly with the Malkoff. I also just purchased a Surefire G2L and planned to replace the P60L with a Malkoff M60WLF, (which I have not purchased yet). I placed the Malkoff M30 in the G2L, (to test) and it does not light up. I disassembled the tailcaps and bezels from the 6P and G2L and compared both bodies. The 6P has shiny silver aluminum throughout the whole body right up to the rim of the top of the threads where the bezel screws down into. This aluminum totally surrounds the Malkoff dropin.
With the G2L, the aluminum is only through the battery compartment and not inserted on the inside top portion of the body. This means the only connection that the batteries have with the Malkoff dropin is by the little spring at the bottom of the Malkoff.
Is it common for the Malkoff to work better with the 6P than with the G2 or G2L?
I purchased the G2L specifically to replace the stock LED with the Malkoff, but I'm thinking maybe its just better to leave the P60L in the G2L and use the Malkoff with the 6P.
Anyone have a similar experience?
Thanks.
Thanks.
