Surefire G2X Explanation
UFO
Can someone here tell me what the difference is between these four Surefire lights:
1. G2X LE
2. G2X Tactical
3. G2X Pro
4. G2X Pro V2.
All replies welcome.
thermal guy
ny
most models are listed here
Slumber Pass
The Alamo City
Single mode lights also have an A or C on the bezel.
Dual Mode Pro (low/high) models have a B or D on the bezel.
A and B were the original 200 lumen models.
C and D can be either 320 or 600, however, if you have a serial number under the C or D, it's a 600.
Mr. LED
Germany
Which is not an actual serial number, just a production control number, as I’ve seen more than one identical unit sharing the same number.
1: High/low
2: High only
3: low/High
4: Probably referring to Gen. 2? 600lm output on high vs 320lm on Gen. 1.
1st run of G2X were 200 lumens, 2nd were 320 lumens and the actual 3rd is 600 lumens.
badtziscool
Wow. Learn something we everyday. I’ve always wondered what those letter designations referred to.
UFO
The 320 lumen G2x Pro was seen as one of the best flashlights ever made in the history of mankind. But if you got one of the green tint biased ones……the worst.
How can one tell the difference before buying one? Are there tell tale signs? The reason I ask is a lot of sellers, even credible ones, sometimes don't even know what they're selling.
Mr. LED
Germany
Best is to look at the LED. 200 lumens version is a small LED with green surrounding board. 320 version is a Nichia 219B, medium size LED with a tiny black triangle on one of the corners. 600 lumens version has a number on the head that looks like serial number (but it’s not).
Slumber Pass
The Alamo City
I have a later revision 320 lumen G2X Tactical that doesn't appear to have a Nichia. It has a gold looking board behind the LED and a cooler tint. This one came with a clicky tail cap and heavy orange peel reflector.
It's gamble what you'll get.
Nichia on Left, mystery LED on right
bykfixer
My own little Idaho
Pretty much all of the 320 lumen G2x Pro are gone and sellers now have the 600 lumen version.
Like Mr L said, there is a set of numbers on the head of the 600 lumen version.
Mr. LED
Germany
This is the one I got, Nichia 219B for the 320 lumen version. I’ve never seen a 320 lumen with another LED, but it doesn’t mean they don’t exist.
The tint is around 5000k (I guess).
