M I K
The clip is a real problem, and detaches with a simple twist.
I did some testing of the SureFire lanyard clip. I think you'll find that if the clip detatches from a twisting motion, that it is mounted on too large of a ring.
Ditch the clip. The clip is a real problem, and detaches with a simple twist. I discovered this the hard way with a brand new C2 that hit the concrete twice from simply lowering and raising my arm with the light hanging by its lanyard.
I don't have a good pic, but you can see in this one how I use a split ring only attached to the lanyard ring(whether SF or LeefRing), with either a knot or adjustable stay close to the light so the lanyard doesn't move around, and the breakaway lanyard closures at the end.
The lanyard is supposed to detach from the hand - not from the flashlight. That would make no sense, if the flashlight falls off but the hand gets injured.If i understand right, Its designed to do that. Most of SF's Lanyards are designed to detach when there is alot of tension for safety (So you don't choke yourself for example). So when your letting it drop, Your exceeding the amount of tension that the lanyard is designed to hold before it breaks the connection and so thats the problem.
I have my M6 since one week and it has happened to me exactly the same. I've been lucky too because all the three times the lanyard has disconnected from the ring the flashlight never dropped on the floor. The last time I noticed the disconnection I decided to remove completely the ring and to not to use the lanyard at all because I thought it was a problem with my lanyard, but now I see that it's not happening to me only.Hello,
I just purchased an M6 and really like it! There is one issue I have had since I purchased it. I have attached the lanyard a few times and THREE of the times it has disconnected without warning!!! I've been lucky because it has fallen on carpet from less than two feet every time (since I've been testing the lanyard out). The last time it disconnected I looked at the clip less than a minute before (while it was attached) and everything looked just fine. If the lanyard spins around as you pick up the flashlight and then you let the light drop it can disconnect. It appears to be either a design flaw because the clip can open upon a single spin or the tension on the clip isn't great enough. To the touch it feels fairly firm. It seems like this should never happen since it is a high quality tactical flashlight! Any ideas?
Greg
Knife wrist lanyards are used by running the whole lanyard around the back of the hand and putting a loop around the thumb only.
Greg
