wrathothebunny
- Joined
- May 7, 2007
- Messages
- 168
I was taking a look at SureFire's website and I noticed some apparent contradictions in lumen ratings between flashlight models. The most glaring contradictions are:
E2D Executive Defender
60 Lumens
1.25 Hours
2 X 123A
A2 Aviator
50 Lumens
1 Hour
2 X 123 A
AND
M4 Devastator
225 Lumens
1 Hour
4 X 123A
M6 Guardian
250 Lumens
1 Hour
6 X 123A
OK, both the E2D Executive Defender and the A2 Aviator run off of 2 123A lithium batteries. However, the E2D is rated with higher lumen output and longer runtime than the A2. Now, SureFire is reported to list the AVERAGE lumen output - or something like that - over the life of the cells. However, the A2 is regulated, so its output should not vary, therefore peak output should roughly equal average output in its case, as the lumen output graph would look like a square waveform. In an integrating sphere test conducted by members here, I recall the A2 measuring at 70-80 lumens. WTF? Additionally, the E2D, running on the same 2x123A setup, would be expected to match the lumen output of the A2, not exceed it.
Now, comparing the M4 Devastator to the M6 Guardian, you have a 4X123A setup putting out 225 Lumens compared to a 6X123A setup putting out 250 Lumens, both at 1 hour. So an additional 2 123A lithiums gets you 25 Lumens? Again, WTF? The M4 is reported to draw about 1.45 Amps, and this would be at about 9.6 Volts. So 1.45X9.6=14 Watts. The M6 is reported to draw about 2.6 Amps at about 7.6 Volts. So 2.6X7.6=20 Watts. So again, moving from a 14 Watt setup to a 20 Watt setup gets you an additional 25 Lumens? WTF?
Taking the LumensFactory 12V D36 Standard model rated at 320 bulb lumens - which is spec'd at 1.3 Amps at 9.6 Volts - then multiplying the 320 bulb lumens by .65 to yield 208 torch lumens - then comparing this 208 torch lumens to the 225 "SureFire Lumens" that the M4 Devastator reports - which is measured to draw about 1.45 Amps at 9.6 Volts - it becomes clear that the M4 is spec'd closer to the maximum lumen output than the average lumen output, and the extra 17 Lumens compared to the LumensFactory lamp assembly is likely due to the slightly higher current draw of the M4.
As a side note, I guess you could conclude that the equivalently 320 bulb lumen rated LumensFactory HO-9 running on 2X17670s would come within just (approximately) 17 Lumens of matching the M4 Devastator's output.
60 Lumens
1.25 Hours
2 X 123A
A2 Aviator
50 Lumens
1 Hour
2 X 123 A
AND
M4 Devastator
225 Lumens
1 Hour
4 X 123A
M6 Guardian
250 Lumens
1 Hour
6 X 123A
