Surefire Maximus, Minimus AA, Minimus Tactical and Minimus Vision!
Greenbean
WNC
Well I will begin testing tomorrow night,
This is going to be my first Surefire headlamp,
I do like the rechargeable version they have out now but I need a headlamp with long term storage battery life, aka CR123 that can live in the truck for weeks at a time.
Greenbean
WNC
The tint is not warm but seems to be a real neutral white and gets warmer in the peripherals.
cland72
Here it is,
I am really wanting to know if it's at least the updated version w/out the light stripe across the nose and such.
The photo with the price is just to see the model number and such.
Closest thing to a white wall to illustrate the beam profile is the fridge.
This appears to be the first gen version, not the most recent version.
Greenbean
WNC
Thanks, I figured it was first Gen but how do I confirm it has the better beam profile?
I have been searching and searching the Internet for comparison photos and can't seem to confirm anything.
gunga
Vancouver, BC, Canada
I think they all have artifacts. It's an XRE LED behind a clear optic. That line at the bottom is the prism effect people describe. It's a bright line on your nose. My late generation one has it a bit too. The glass frosting spray fixed my beam issues and gives me a nice smooth flood.
Greenbean
WNC
Hmmm,
10-4,
Guess the test later tonight will see what comes of it.
gunga
I did a rather poor job (old norland?) but the coin slot on the new minimus is a good fit for a 2x12mm trit.
P_A_S_1
NYC
I have the newer version and it has the 'prism' effect. At first I didn't notice it but now it's quite pronounced and seemed to get worse with use. Of all the minor issues with the minimus it is the most annoying.
Kestrel
Willamette Valley, OR
The more I use my Minimus Vision, the more I get the feeling the battery is draining a lot faster than it should. Do any of you feel like the battery is going dead long before you think it should?
Example: I replaced the battery and used the light for about 20 minutes. Next time I pulled it out of my bag, I turned it up to full brightness and it gave me the low battery warning flash. This all occurred within the last 3 months. I use USA made CR123 cells.
Thought I read somewhere doing some research on the internet that some of the models of the headlamp were prone to rather thought I read somewhere doing some research on the internet that some of the models of the headlamp for prone to rather high parasitic drain, one user always loosens his battery compartment before putting it in his glove box.
Recently I have been using fresh SureFire CR123's with this light, and I'm starting to suspect that mine behaves like this as well. :thinking:
P_A_S_1
NYC
Might be what's going on,
IDK about the first generation but on the newer models with the knurling this won't work. The moment the battery cap makes contact with the body there is a connection so short of removing the battery you'll get a little drain. There is no lock out feature.
mbw_151
Oregon
I just checked the Minimus headlamps I put in my cars and truck about a year and a half ago, all flat. I put a new cell in with electrical tape on the positive end. Not the most convenient approach, but the cell won't be flat. There is a 6P in the glove box too so if I need light fast, that's not an issue.
Kestrel
Yup, have checked the fresh cell that went in a few months back, and get the low-voltage indication on it as well.
So now that this behavior has been verified on my relatively-recent-production Minimus Vision, I admit that I'm a little disappointed.
Guess I'll have to use some sort of non-conductive insert in mine as well as Mrs. Kestrels'. :(
pulstar
Slovenia
How did that work out for you? After a year my minimus vision also developed pronounced prismatic reflection. I don't know why, when i first recieved it, there was none.
Did glass frosting spray resolve that issue? How about overall brightness, did you loose some?
gunga
While overall brightness is likely reduced, the frosting spray makes the beam smooth and floody. I don't have the reflection issue. It's much better. Not fun nor perfect but it works. I'm not a big fan of the size and old LED, be there is no other headlamp with this UI.
Btw, I think I may have the parasitic drain issue too. I can't warranty it because it's discontinued.
P_A_S_1
NYC
Mine did too. How can that be, so odd.
pulstar
Slovenia
I wouldn't mind sending it back. Lifetime warranty FTW:) On the side note: Has anyone already called Surefire about that issue? I would, but international calls are quite expensive and being foreign speaker there's an ever problematic language barrier. I can write and talk quite good, but specific conversations with native english speakers soon prove that wrong:)
