I have a Surefire M3 that I tried to modify with a Cree R2. The LED module burned out and I'm going to put in an MN11 lamp.
When trying to put the MN11 (& MN10) reflector back in, I can't get it back in the shock isolation foam piece that loops around inside the head. The foam has started to tear in several places. Every time I try to push the reflector inside of the foam the foam either bows in so that the reflector is above the foam and the foam donuts downwards, or the reflector is at an angle and one side begins to donut downward. I literally struggled with it for 2 hours the other day.
I thought about putting glue on the outside of the foam, maneuvering the foam in place and letting the glue dry before attempting to put the reflector in. I'm concerned with the combination of heat and the glue, however...
Does anyone know if this glue/foam combination will light on fire or cause any kind of problem?
If this does present problems does anyone have any other ideas on how to get this in? Is there thinner foam that I've not found yet?
