Surge bulb in 4AA light?
Chuen
Hong Kong
I observe that my surge runs pretty well with only 4 nimh AA. Anyone know of a bi-pin 4AA light that can take the surge bulb? I know somebody try it on a tec40. But I don't want to make the PR base adapter.
Bushman
I don't know the bi-pin width on the surge bulb but Carley lamps sells pr base to bi pin adapters for next to nothing. Lemlux would be able to tell you.
lemlux
San Diego
The T-1 3/4 Surge bulb has a narrower pin configuration than the Carley #912 socket. I know of no PR adapter base that will work with the Surge lamp.
Nerd
Singapore
and since my surge lamp burned after i applied 7 volts to it with a variable power supply, I haven't manage to get a new bulb from my local dealers, said that the bulb will come in one month.... and to think i got the torch for less than a week..... this tells us that itchy hands only pays if you have a big pocket.
D
**DONOTDELETE**
Guest
Nerd, did you have the voltage set at 7 or higher and then burn it out as you turned up the amperage? (Just seeing if I understand this power supply adjustment stuff..)
