T4K, or something else...
tookie
Background. I've had a Nitecore TIP for awhile, as well as a bunch of other flashlights that uses everything up to a 18650 rechargeable. I'm not opposed to a more typical flashlight, but something that would be as pocketable as a T4K, nothing bigger.
==================Flashlight Recommendation Checklist================
This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____Up to $100.
3) Format:
____I want a flashlight (hand held/self contained).
4) Size:
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
Rechargeble, integrated or not is ok.
If able to also use AA as a backup, that would be neat.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
Open to all of these.
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
T4K Style, crazy turbo, but with very usable normal levels.
Not too particular on this
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I am searching from a helicopter)
Variety of all of the above.
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
Good runtime on at least a "mid" setting of around 60-80 lumens
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____Any size switch will do.
____I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
Doesn't matter too much, as long as it is durable.
15) Water resistance
____IPX4 (Splash resistant)
16) Storage conditions
____Emergency kit (long standby periods)
____Pocket/belt clip, especially one that can be used to clip on a hat
Thank you everybody!
