msloshooter
- Joined
- Nov 23, 2008
- Messages
- 46
As many of you know several people on CPF (myself included) were selected to receive a TA30 from Fenix for reveiw. There are a couple of very good reveiws on the lights allready, so rather than do a complete review, I decided to focus on the light from a Law Enforcement perspective. I have taken some photos in comparison to a Streamlight Stinger because that light is very prominent in Law enforcment.
Here the TA30 is side-by-side with the Stinger. As you can see my stinger (which I purchased 13 years ago when I worked at the prison) is well worn from many years of use. The TA30 is about the same size and weight. The main difference is the sharp crenelations on the bezel (shown below).
These crenelations are intended to be a strike bezel. However they are actually very sharp. The problem this creates is when wearing the light on a duty belt. I carried the light in my stinger holster (it will fit in Stinger holsters, it fit mine and one of my partners with a cover strap), but my holster does not have a cover strap. After only two days of use it began to abraid my uniform shirt. I believe it would take only a couple of weeks before it would wear a hole through the shirt. If you have a holster with a cover starp it would prevent any additional wear on a uniform shirt.
This is the only issue I have with the light. Other than that there is almost no comparison to the Stinger. The TA30 has a claimed output of 225 lumens and the Stinger 125 lumens. Fenix tends to be honest about the output of their lights and from others who have tested lights like the T-1, I have no doubt about the output claim. The higher output along with a runtime of 3.5 hours compared to the Stingers 1 hour make the TA30 a very attractive choice.
Here is a shot of the two lights from the buisness end. Although the stinger has a larger reflector, it has medium to heavy orange peel. The Fenix has light orange peel. In compairing the two beams there is very little difference in throw but the Fenix has more flood because of the higher output. I compared the TA30 to my TK11 and the reflector looks to be about the same size. I don't have a TK10 but I assume the reflector would be the same with probably similar orange peel. I am stepping out a little but I'm going to say that the beam will be about the same as the TK10.
Another great feature of this light is the selector ring. This is the first time I have used a light with this type of output adjustment. I have a TK11 with the output adjusted by turning the bezel. The bezel adjustment works but it can be tight due to the o-rings. The ring is easy to reach and easy to adjust. You can set the level and there is visual reference points so you don't have to turn the light on to make sure what level you are on. In my opinion this UI system is just about perfect for duty use.
All in all this is a very good duty light. Some people think it might be too big for duty use and I would strongly disagree. It is about the same size as a Stinger and only a little bit longer than a Surefire M3 combat light (which one of my partners uses and I would put the TA30 up against anyday). I highly recommend this light to anyone who is in Law Enforcement or security. It would serve for many years and I believe would be a "go to" light.
Matt
Edit: Moderators, I could not post in the reveiw section so I had to port here.
Matt
