Tana Light Engines for McGizmo lights (Haiku, Mule) and modding service...
Another "SuperCRI" module I made a year or so ago... Mule config only but interesting idea from a member who was persistent enough to push me into making it... 🙂
Rocking H17(-F) and still going strong...
Yes, but the haiku has a great reflector. I still prefer a super LE than a triple in this litlle light, a Tana super LE of course...
Sent you an email but thought I'd reach out here too. I've got an original style (non-HRU) Sundrop that I'd like to upgrade with one of your engines. Would the SuperLE be a viable option? I'm thinking about a warm Nichia 219b for the emitter. Thanks!
Like Spaceman said, I did get an email and already replied... I am aware there are two different versions of Sundrop heads and knew to some degree what the difference is using different LEDs, etc...
Like I told him I'm building one just these days for member in Germany... the way I approached it is to make it possible to use in both Haiku and Sundrop without need for spacer/insulator on any part of board to prevent short against smaller diameter in Sundrop or wider in Haiku/Mule... all while keeping in mind those tiny tolerances that can be seen even in comparation between older and newer Sundrops, not just between Haiku/Mule and Sundrop in general...
Hi everyone, I haven't found how you change the programming on the Lana LE as I just picked up a McGizmo Mule with the Lana LE and am trying to change it. Right now it is super dim, dim then super bright. On the chart I guess group 10 is what I want on the chart. Thanks for your help.
Reese
Sorry for delay... I didn't check CPF in a while but I believe that you found me on FB as I had same question in messages about 10 days ago... it was H17F driver and SuperLE module...
Hi Tana/all - I just unearthed my old McLux III PD! what mods could be done to get it "modernized" ? I'm guessing only a LED swap given the piston drive/twisty mechanics...
I was also in the market for your mods, Tana. I spoke with datiLED about UV light engines, and am now looking to take my first descent into the Tana mods rabbit hole. Particularly, I'm interested in the Super LE first, will likely get into a triple conversion when I've got some more funds. What's everybody's current consensus on the favorite LED for the super LE?
Replying to both via email... sorry for delay, guys...
Would you be willing to make this again?
Thank you for the reply, not long at all Tana! Looking forward to your work.
I've read the whole thread, and I have a few questions, if anyone feels inclined. I had thought that in order to get a Tana LE, I would need to send my head to him, and he would send the head back with the LE installed. However, in answer to this question when asked earlier in the thread, it was explained that you just unscrewed the old one from you head and add the new one. Now I'm thinking its only necessary to send the head when it requires modification, such as with wanting a triple, otherwise a single led Tana LE would be like a drop-in, and you just unscrew and remove the old LE and screw in the new one. Am I understanding this correctly? If so, does the new Tana LE still use the old reflector or come with a new different reflector, like a P60 drop-in would.
My second question on which I would appreciate people's opinions on is when you get a Haiku triple from Tana, do you "retire" the old McGizmo LE, or get a second head so that you can use both. I am trying to understand the strong preference people have for the triple in the Haiku since I have heard so much about how great the McGizmo Haiku is as provided by Don. I am considering getting one, and trying to understand what to start with. I have several triples and a quad, all Nichias, in my 18650 and 1835 lights, but not in my smaller lights, which the Haiku would be. On the one hand, a Tana triple would turn the smaller light into more of a larger light experience. But since it was designed as an excellent one led smaller light, I wonder what am I giving up and why people prefer the triple.
Thanks in advance.
