redlaw55
- Joined
- Aug 25, 2007
- Messages
- 16
The Target clearance continues randomly at stores throughout the country.
I purchased what is shown in the photo, but there was more, and cheap.
From left to right:
River Rock NightFire 60 Lumen focusing light with 2AA batteries. 30,000 hour, vanilla tint, Rebel 60 LED. Has an orange, rear clicky, on/off switch. 8 hour run-time. Light is adjustable to a wide FLOOD with a very evenly dispersed beam. This is a great work light at distances of 1 to 3 feet. (Price was $5.24, marked down from $20.99)
River Rock .5 watt LED flashlight with pen clip. Bright white tint, runs on 2 AAA batteries, 7 hour run-time. Rear momentary switch, screws inward for constant light. Led is round, not square, probably chinese origin. Led is good for up to 10,000 hours, not 100,000. ($2.38, marked down from $9.54)
Dorcy Luxeon K2 LED flashlight, 6 watt, 3 AAA batteries, 120 Lumens. Same flashlight as in the 160 Lumen package, but there is a much better chance of getting an LED with discoloration. Light has a rear clicky, on/off switch with a Green to Red, built-in battery indicator. Throw is a bit farther than a Cree 3 watt with similiar lens, and the illuminated area at a distance is double. This light appears to have been replaced with a similiar model equipped with a forward-clicky and no battery indicator. (Price was $7.82, marked down from $31.29)
Brinkmann 3 watt LED Headlamp with 3 AAA batteries. Inside is a black Cree star which is screwed to a metal plate. This light produces a bright white beam with artifacts, including the Cree ring artifact. Reflector was about the same size as in the Dorcy K2.... A one watt Lux will be the replacement LED here, while the 3 watt Cree will improve a handheld light. (Price was $5.24, marked down from $20.99)
Last, an Energizer 1 watt LED light, w/Optic lens, and 2AA batteries. The optic lens provides an evenly formed, soft, fuzzy spot that lessens eye sting in close quarters. Tint is about the same as the RiverRock NightFire. (Price paid, only $3.24 !!!)
Target stores that are not heavily trafficked, recently opened, poorly located, etc., have a more likely chance of a good clearance. Look for lights at the end of an isle away from the flashlight area. I found these lights next to the Electrical and Hardware dept.
For fast loading, and no waiting, the photo posted has a file size of 56 kilobytes.
From left to right:
