Team Products 3-LED mini-review + photos
idleprocess
decamped
QUICK SPECS
  • Light source LED - 3x5mm
  • Type Medium flashlight
  • Switch Momentary
  • Operation triple-mode
  • Operational sequence Off (faint glow) | 1 LED | 2 LED | 3 LED
  • Driver Unknown buck driver
  • Power source Alkaline: 4xAAA
    Rechargables not effective
    Lithiums should work fine
  • Focus Fixed
  • Beam Medium spot
  • Construction Molded plastic
  • Environmental
    Water resistance: Moderate
    Shock resistance: Minimal
    Crush resistance: Minimal
  • Availability
    Originally purchased at Big Lots
Flat view
Perspective view
The business end
Assembly view
(snide) COMMENTS
  • "Sub-milliamp" glow in 2 outer LEDs when light is "off"
  • Solid-state switching
  • Average white LED tint
  • Average brightness for 3x 5mm LEDs
  • Rechargable cells do not power light well enough
  • Tailcap is retained poorly - any force against it will likely break adhesive retaining block that tailcap thumbscrew threads into
  • Reflector does next to nothing for beam profile
  • Suggested use: giveaway
I, not so regretably, returned one of these to Big Lots thinking it wasn't supposed to glow all the time. It did seem to be especially second-rate. Thanks for your reviews.
Geoff
I'm not sure if the constant glowing is an intended feature, or just the bi-product of a hastily-implemented solid-state switching circuit.
I've had mine for a long time, and the batteries are still going strong.
