Originally posted by Lux Luthor:
How do these lights compare? I have a lot of experience with the Tec 40, but I'm getting a little fed up with the lack of a switch.
Are these other lights any good? I'm particularly interested in the quality of construction of the lights, in addition to any beam comparisons.
<font size="2" face="Verdana, Arial">Lux,
You might want to audition UK's upgraded 4AA with the new body switch, running the 14801 lamp module. This combination will give you one of the smallest (with very small bezel), brightest, *waterproof, shockproof, ergonomically designed and reliable 4AA flashlights that I've seen.
The new switch is unique. It is a beautifully functional body-mounted clicky that falls naturally under the thumb in switch-up position or under the first finger in switch-down position.
It is cleverly integrated into the body and takes up literally no extra space.
The 14801 lamp (AKA "480") looks like the typical 4AA/Q40/2L UK module except for the black outer reflector surface stamped either 14801 or 480.
This is either a new lamp module or one I haven't seen before. Although the reflector is not textured, UK has found a way to create a highly focused long-throw beam, somewhat narrower than the typical UK beam, with a very bright center and bright surround. I have three of these lamps and they are almost identically consistant and noticeably brighter than my TEC 40 though without the familiar smoothness typically provided by textured reflectors.
I enjoy now having a choice between the #480 and the more common UK lamp which provides a wider but somewhat inconsistant beam.
I have only one criticism of this light, and it may sound like nitpicking. It is about 1/4" longer than the Mini Q40, and I always prefer the smallest light possible. UK has chosen not to put their excellent new switch on the Mini Q40, but with proper lubing its conveniently ridged rubber bezel allows for convenient one handed operation.
Between the Mini Q40, 4AA with switch and the 2L plus the 14801 lamp in addition to the typical lamps, UK has provided us with an even greater choice than in the past
* While the Mini Q40 is UK's 4AA divelight, the new 4AA with clicky is fully waterproof to at least 10 feet. It also is certified for explosive environments.
Brightnorm
