KiwiMark
Also, since you are charging loose cells, there is no need (or advantage) to balance charge them in series - just charge them in parallel. Here's how I charge 1-8 cells at the same time.
There is one obvious disadvantage to charging in parallel - you have absolutely no way of knowing how much capacity is going in each cell. If they are all the same model/age cell that are drained together you could GUESS that they will each take about the same as each other, but if one cell is failing you wont be able to tell when charging.
Balance charging enables you to get data on each cell - you can even graph it to see how each cell compares to the rest.
I'm not saying that parallel charging wont work just fine, just pointing out a drawback.
As I said though, some of the newer Li-Ion cells may actually be different.
