skunksoup,
If your cells are 3.7V type, then the Pila charger should be OK, it will not charge any of the "3.0V" cells correctly.
42,
I'm sure you are already aware, that 3.7V cells are usually "overdriving" the P2D anywhere from a little to a lot, it's kind of the mercy of the Vf of the LED. I thought I remember reading somewhere that as LEDs age, their Vf can drop a little, this could cause more current to flow than used to when being direct driven by the RCR123. I doubt that is what is happening but I just want to point out anything that comes to mind. If you have a current meter it might be worth checking current across the tail-cap just to eliminate this unlikely possibility.
Storing li-ion in a state of full charge does cause an increase rate of cell aging. They should be stored for long periods at about 3.9V. Tends to be that higher quality brands of li-ion cell are the best at resisting the effects of aging. It would be my guess that the cells simply aged rapidly due to a combination of being stored at a full charge and the fact that tenergy is known for having a less than superior product when compared to other name brands.
[edit in] if you have a volt meter, please test the voltage that the cell is coming off the charger, and then test it again after the cells have rested for awhile and see what happens. If they are not holding above 4.0V then that is another indication of simply being heavily "aged" cells.
Eric
