HKJ
[size=+3]Amazon Basic AA 2500mAh (Black)[/size]
Official specifications:
Maximum temperature raise at different discharge currents: 1A:+1,0°C, 2A:+2,8°C, 3A:+5,2°C, 5A:+10,4°C, 7A:+16,3°C, 10A:+23,1°C
This is the high capacity NiMH cells from Amazon (The black cells does also exist in a lower capacity version).
Very good discharge curves with perfect tracking between the two cells.
[size=+3]Conclusion[/size]
The cells has very good performance.
[size=+3]Notes and links[/size]
How is the test done and how to read the charts
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
- Typical capacity: 2500mAh
- Minimum capacity: 2400 mAh
- Nominal voltage: 1.2V
- Life: 500 cycles
- Low self discharge (LSD), 75% capacity after one year, 65% after 3 years
