HKJ
[size=+3]Ampsplus 14500 1000mAh (Black) 2020[/size]
Official specifications:
This is a high capacity LiIon 14500/AA sized cell from Ampsplus.
The two cells match nicely. The cell is rated for 1A, they handle that easily and can also handle 3A.
[size=+3]Conclusion[/size]
This looks like a good high capacity 14500 cell, it handles the rated 1A current very easily and it do not fall flat if more current is drawn.
[size=+3]Notes and links[/size]
The batteries was supplied by Ampsplus for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
- Battery Size: Ø14.05mm x 49.90mm
- Nominal Voltage: 3.70V
- Nominal Capacity: 1000mAh
- Min Rated Capacity: 950mAh
- Chemistry: Li-Ion
- Charging Method: CC/CV 4.20V ±0.05V
- Discharge Voltage: 2.75V (Average Cut Off)
- Standard Charging Current CC: 500mA
- Continuous Discharge Current: 1000mA
- Max. Discharge Current: 3A
- Weight: 20 gr. max
- Colour: Black , Silver
- Protection Circuit Board / PCB: No / Unprotected
- Version: Button / Nipple Top
- Type: Rechargeable , NMC
