HKJ
[size=+3]Camelion AA Premium 2300mAh (White)[/size]
Official specifications:
Maximum temperature raise at different discharge currents: 1A:+1,4°C, 2A:+3,4°C, 3A:+5,9°C, 5A:+11,5°C, 7A:+17,2°C, 10A:+24,5°C
Camelions medium capacity and LSD (Low Self Discharge) NiMH batteries.
The discharge curves looks good with just about perfect tracking between the cells and some performance at high current.
[size=+3]Conclusion[/size]
The cells has good current performance, but capacity is a bit low. The LSD performance is not in top for medium capacity cells.
[size=+3]Notes and links[/size]
How is the test done and how to read the charts
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
- Capacity typical: 2300mAh
- Capacity minimum: 2200mAh
- Nominal Voltage: 1,2V
- Dimensions (Ø x L mm): 14,1 x 50,5
- Weight (g): 29,0
- Electrochemical System: Nickel-Metal Hydrid
- Low self discharge: 90% after 6 months, 85% after 1 year.
