Test/review of E-Stream ES18650-29MP 2900mAh (Green) 2021
HKJ
Copenhagen, Denmark
[size=+3]E-Stream ES18650-29MP 2900mAh (Green) 2021[/size]
Official specifications:
  • Capacity Nominal: 2900mAh
  • Capacity Minimum: 2750mAh
  • Nominal Voltage: 3.7V
  • Discharge cut-off voltage: 2.75
  • Maximum charge voltage: 4.2V
  • Intern impedance: <=28mOhm
  • Standard charge current: 1.425A
  • Standard charge cut-off current: 142.5mA
  • Maximum continuous charge current: 2.9A
  • Maximum pulse charge (<2s): 5.7A
  • Standard discharge current: 2.85A
  • Maximum continuous discharge current: 10A (With 60°C cut-off)
  • Maximum pulse (<1s) discharge current: 15A (With 60°C cut-off)
  • Cycle life: 1000 cycles to 80%
A 2900mAh LiIon battery with moderate current rating.
The two cells is fairly well matched and the cells can deliver the rated 10A
[size=+3]Conclusion[/size]
The batteries looks fine, they do not set any records in either capacity or current, but are more average.
[size=+3]Notes and links[/size]
The batteries was supplied by E-Stream for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
