HKJ
[size=+3]GTL 26650 12000mAh (White)[/size]
Official specifications:
Super high capacity 26650, again a battery with wrong specifications.
There is significant difference between the two batteries and the capacity is 2000 and 2200mAh at low current. The batteries can handle up to about 7A.
At 7A the A cell get warmest.
At 10A it is the B cell.
[size=+3]Conclusion[/size]
These cells where never going to be anywhere near the rated capacity, instead they have less capacity than most other 26650 cells.
I will call them bad cells.
[size=+3]Notes and links[/size]
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 26650 and other batteries
- Model: 26650
- Type: Rechargeable Li-lithium battery
- Capacity: 12000mAh
- Voltage: 3.7V
- Max Continuous Discharge: 8A
- Max Peak Discharge: 4A Peak lower than continuous?
- Size: about 66*25*25mm
- Colour: White
