HKJ
[size=+3]Sanyo UR18650SA 1200mAh (Red)[/size]
Official specifications:
A old fairly high current cell with low capacity (Datasheet is marked 2008).
The discharge charts looks good, capacity is constant at any current and the two cells matches.
[size=+3]Conclusion[/size]
This is an older high current cell for tools, the last 10 years has improved cells significantly.
[size=+3]Notes and links[/size]
Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
- Nominal capacity: min. 1200mAh
- Nominal voltage: 3.7V
- Charging method: CC/CV
- Charging current: std. 840mA
- Discharge current: 10A
- End of discharge: 2.5V
- Ambient temperature: Charge: 0°C ~ 40°C, Discharge: -20 ~ 60°C, Storage: -20°C ~ 50°C
