Test/review of Vapcell INR16650 2000mAh M20 (Gold) 2020
HKJ
Copenhagen, Denmark
[size=+3]Vapcell INR16650 2000mAh M20 (Gold) 2020[/size]
Official specifications:
  • Typical Capacity: 2000mAh
  • Min capacity: 1950mAh
  • Nominal Voltage: 3.6V
  • Charging Voltage: 4.20+-0.05V
  • Discharge End Voltage: 2.5V
  • Max. Continuous Discharging Current: 8A
  • Dimensions: 65.0mm (L) x 16.5 mm (D)
  • Max Weight: 38g
Vapcell LiIon batteries in 16650 size.
The batteries tracks nicely, but voltage and capacity drops a at higher current.
Discharge-Vapcell%20INR16650%202000mAh%20M20%20%28Gold%29%202020-pulse-1.0%2010%2010-IR.png
[size=+3]Conclusion[/size]
Usually 16650/17650 cells are based on a 4.35V Sanyo cells, but not these cells and they can deliver considerable more current.
[size=+3]Notes and links[/size]
The batteries was supplied by Vapcell for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
