Test/review of Vapcell INR18350 1400mAh F14 (Green) 2021
HKJ
Copenhagen, Denmark
[size=+3]Vapcell INR18350 1400mAh F14 (Green) 2021[/size]
Official specifications:
  • Minimum Capacity: 1350 mAh
  • Typical Capacity: 1400 mAh
  • Nominal Voltage: 3.6V
  • Charging Voltage: 4.20V
  • Standard Charging Current: 0.5A
  • Discharge End Voltage: 2.5V
  • Max. Continuous Discharging Current: 3A
This is a high capacity 18350 cell.
The two cells match nicely and the can deliver the rated 3A, but are as expected not very good at higher current.
[size=+3]Conclusion[/size]
This is a good cell when a lot of capacity is desired.
[size=+3]Notes and links[/size]
The batteries was supplied by Vapcell for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
