Test/review of Vapcell INR18650 2400mAh (Purple)
HKJ
Copenhagen, Denmark
[size=+3]Vapcell INR18650 2400mAh (Purple)[/size]
Official specifications:
  • Model: INR18650
  • Size: 18.3*64.8mm
  • Nominal voltage: 3.6V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50V
  • Typical Capacity: 2400mAh (0.2C discharge)
  • Min capacity: 2300mAh (0.2C discharge)
  • Weight: Max:46g
  • Internal resistance: Max:10mOhm
  • Standard Charge: 1000mA,CCCV 100mA cut-off
  • Charging Time: 3.5hours(standard charge)
  • Quick Charge Current: 4000mA
  • Max Continuous Discharge Current: 30000mA
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: -20°C~70°C
  • Storage: Temperature -5°C~35°C, Humidity <75%RH
  • Standard environmental condition: Temperature: 23±5°C
  • Humidity: 45-75%RH
This is a high current cell with not that much capacity.
The two cells tracks nicely and they can deliver 30A.
I had to skip the temperature curves, I forgot to replace the battery (It last about a year).
[size=+3]Conclusion[/size]
The battery is a bit low in capacity, but it can deliver a lot of current.
[size=+3]Notes and links[/size]
The batteries was supplied by Vapcell for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
