Test/review of Vapcell INR18650 3000mAh V2.0 (Purple) 2021
HKJ
Copenhagen, Denmark
[size=+3]Vapcell INR18650 3000mAh V2.0 (Purple) 2021[/size]
Official specifications:
  • Model: V2.0 INR18650 3000mah 20A
  • Size: 18.3*64.9mm
  • Typical Capacity: 3000mAh (0.2C discharge)
  • Min capacity: 2900mAh (0.2C discharge)
  • Nominal voltage: 3.60V
  • Max Continuous Discharge Current: 20A
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Weight: 48g
  • Internal resistance: 12mOhm
  • Standard Charge: 1500mA,CCCV 100mA cut-off
  • Quick Charge Current: 4000mA
A unprotected 3000mAh 18650 with fairly high current.
The two cells tracks nicely and capacity do not vary much with load.
Discharge-Vapcell%20INR18650%203000mAh%20V2.0%20%28Purple%29%202021-pulse-1.0%2010%2010-IR.png
[size=+3]Conclusion[/size]
This looks like a good battery that can deliver a lot of current and it has a low internal resistance.
[size=+3]Notes and links[/size]
The batteries was supplied by Vapcell for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
