Test/review of Vapcell INR21700 5000mAh G50 (Gold) 2020
HKJ
Copenhagen, Denmark
[size=+3]Vapcell INR21700 5000mAh G50 (Gold) 2020[/size]
Official specifications:
  • Model: G50 INR21700 5000mah 15A
  • Size: 21.1*70.5mm
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Typical Capacity: 5000mAh (0.2C discharge)
  • Min capacity: 4900mAh (0.2C discharge)
  • Weight: Max:72g
  • Internal resistance: Max:15mOhm AC 1kHz
  • Standard Charge: 1000mA,CCCV 100mA cut-off
  • Quick Charge Current: 2500mA
  • Max Continuous Discharge Current: 15A
A high capacity 21700 battery.
The two cells tracks nicely and as expected this high capacity is not very good at high current.
Discharge-Vapcell%20INR21700%205000mAh%20G50%20%28Gold%29%202020-pulse-1.0%2010%2010-IR.png
[size=+3]Conclusion[/size]
This is a good high capacity cell, but best suited to loads that has an average value at or below 10A.
[size=+3]Notes and links[/size]
The batteries was supplied by Vapcell for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
