Test/Review of Windyfire IMR18350 850mAh (Red)
HKJ
Copenhagen, Denmark
[SIZE=+3]Windyfire IMR18350 850mAh (Red)[/SIZE]
Official specifications:
  • Type of Battery: IMR 18350/850mAh
  • Size(mm): 18mm(Diameter) x 35mm(Length)
  • Positive Shape: Button top
  • Weight(g): 22±1g
  • Nominal Voltage: 3.7V
  • Nominal Capacity: 880mah(0.2 C Discharge)
  • Minimum Capacity: 850mah(0.2 C Discharge)
  • Discharge Cut-off voltage: 3 V
  • Standard Charge: 0.4 A /4.2V
  • Maximum charge current: 0.85A
  • Quick Discharge Current: 0.85 A
  • Max Discharge Current: 4 A
  • Initial Impedance : Max:65mOhm
  • Cycle Life: 310times: discharging capacity>85%, 510times: discharging capacity>60%
  • Temperature Characteristics: -10°C/0.2C >80% Capacity; 20°C/0.2C =100% Capacity;60°C/0.2C >95% Capacity
  • Charging Time: Standard charge : 5-7hours, Rapid charge : 2-3hours
  • Operating environment: Charging, 0°C ~ 45°C ; 65±20%RH, Discharging, -20°C~60°C ; 65±20%RH
  • Storage environment: Temp(-20°c -35°c) / Relative humidity (45-75%)
This is a IMR cell, but only with moderate high current ability, but good capacity.
The cell does fine up to 3A load, but at 5A load it loses significant capacity.
[SIZE=+3]Conclusion[/SIZE]
These batteries has good performance at moderate loads and I will rate them acceptable.
[SIZE=+3]Notes and links[/SIZE]
The batteries was supplied by Windyfire for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Comparison to other LiIon batteries
weegidy
Arizona, USA
Thanks! This will be great for my new laser :)
I've been using AW 18350s, but this looks like it has a better capacity.
