Russel
I don't remember the material sizes of the top of my head, but I'll look when I get home and post more info. Do you have a mill and or lathe?
I have neither. However, if you can just provide a link to the white plastic "dummy" cell and the brass ends, I will be able to fabricate the rest myself.
I wonder if there is a place that sells good quality brass or copper springs. I have one of the original 2 D cell black battery holders (I got it from Radio Shack) and if I can get a better spring with less resistance I'll be good to go!
Darn. I wonder where to get a teflon rod like that? Would me cutting a wooden dowel into pieces that's the width of an AA cell be a good idea instead? If you don't know where I could get a teflon rod like that?
I just got a great deal on Tenergy D 10,000 mah cells on ebay. THey are the model number 10100. Of the five modes of the MH-C9000, which is the best for D cells? And what did you put as the charge and discharge rates?
OnlineMetals has nylon rod, as well as many other plastic and metal materials. Both wood or plastic would work for making a dummy cell.
For normal charging of 10000mAh NiMH cells, I use a MH-C808M charger at it's default rate of 2 amps. I do however use the MH-C9000 to run the D cells on a break in cycle once a year. I set the break-in capacity to 10000mAh.
Unless you have one of the original MH-C9000 chargers, it won't fully charge a 10000mAh cell in one cycle. The break in mode does work with large capacities, but I think the other charging modes are limited to something like 4500 to 5000mAh. (The charge capacity max. is in this thread somewhere) To charge large capacity D cells with the C9000 you could always set a 2000mA charge rate, then when the charger stops due to it's programmed maximum charge capacity, simply start another charge cycle and it should completely charge the D cell, assuming the cell was completely depleted. Of course, if the cell needs less than say 4000mAh to fully charge it, one charge cycle will do the trick.
C & D adaptors are now made by Maha for the C9000!
Go get 'em...
...Is the C9000 still considered the best all-round charger out there nowadays?
Has it had some major revamps in the last few yrs, wondering if I should sell mine & get the latest revision.
Go get 'em...
