Testing procedures?
Overload
Colorado, USA
I received my light meter last night, and am trying to figure out how to test brightness of my lights.
I believe I need to hold the lights from 1 meter away, correct?
I have a max brightness setting, but I can't get repeatable results.
How does everyone actually conduct their tests?
Overload in Colorado
If you have a Wavetek Meterman LM631, you can set the meter to FC (foot-candles), and hold the business-end of the flashlight 12" away from the sensor on the meter. The reading on the meter LCD will be in foot-candles. If you have the meter's range at its highest setting (x10), multiply the reading by 10 to obtain foot-candles.
The meter does have a setting for LUX, but I've not used it so I don't know what you'll need to do in that case. I believe you hold the business-end of the flashlight 1 meter from the sensor, but I don't have positive verification of this.
Well, I'm using a CEM DT-1301 Light Meter. It does have FC and Lux settings, and well as a 10x setting. The unit is marked 200,2000,20000[x10],50000[x100]. I'm not sure what the numbers mean.
I'll give your metheod a try and see if my results match or are close to your web page.
thanks,
Hello Overload,
Crag has it right. You measure foot candles (fc) at 1 foot. To measure lux you go to 1 meter. To check your meter for consistency 1 fc (at 1 foot) = 1 lux (at 1 meter).
Remember that you are reading the brightest area of the hot spot to compare your reading with listed readings. You can also measure the spill light and form a ratio of hot spot to fill to further describe the beam from a flashlight.
The numbers are the scale for the reading. If you want to read 150 fc (or lux), you can use any scale. If you want to read 10000 fc (or lux), you can not use the 200 or 2000 scale.
To convert from fc to lux, 1 fc = 10.764 lux.
To convert from lux to fc, 1 lux = 0.0929 fc.
To obtain the light output at the source we refer to candela (cd). LED output is quite often specified in millicandela (mcd). mcd = cd X 1000. For example Craig has the Dorcy 1 LED flashlight output listed at 21600 mcd. This equals 21.6 cd.
Doug (Quickbeam) has excellent charts showing the relative throw of the lights he has reviewed. His throw figures are obtained from the Lux output of the beam factored by the inverse square law. If you take the square root of the Lux reading, you will get the distance in meters that the light beam will throw when the reading drops to 1 Lux. If you use fc, the square root of fc will give you the distance in feet that the light will throw with the reading dropping to 1 fc.
If you measure the light from a flashlight outside of the "standard" distance of 1 foot for fc and 1 meter for lux, you can use the following formula to compare readings:
cd = fc * feet squared or
cd = lux * meters squared.
Hope this helps.
Tom
Edit to correct formula - sorry.
