Hello Everyone! Kind of a newbie here, but definitely an enthusiast! I've been doing research on Li-ion/polymer, LifePO/4, Ni-Zn, Ni-MH, and Ni-Cd technologies. I've studied a lot and jumped around a lot to obtain my information, so forgive me if I can't exactly recall what came from where... =/
That out of the way!...
PowerGenix NiZn: Tested fresh out of the package. Please note that the voltage axis is scaled differently than the other comparisons.
I'm very curious about the Ni-Zn technology, since it appears to be such a great and safe replacement for many Ni-Cd/Ni-MH packs, where Li-ion would not provide a close enough voltage in terms of toy RC's. (I've been making packs for my son's and niece's cars that allow you to remove individual cells to charge them on a standard charger and be able to balance [albeit by manual voltage readings, lol] each cell).
I also bought some extra's for his mom's Sony camera. Since I've personally used it with alkalines and know of it's voltage shut off tech, I figured she'd get much more use and faster recycle times with the Ni-Zn tech... but here are my Concerns...
I recently contacted PowerGenix, since I've seen on different sites, about the periodic "Maintenance Charge." I've seen different stuff about this. Some says monthly, some every other month, some to not let it drop below 1.68v in storage... So I asked them about it and, after an initial charge, if I just so happened to store a cell for months before use, how would effect the performance/life, etc. of the battery... This is what they told me.
Thank you for your inquiry. Optimum cycle life will be achieved by limiting the individual cell voltage at 1.1 Volts (or greater) at end of discharge. Failure to do so will likely result in deep discharge of some batteries, often resulting in polarity reversal, which is detrimental to overall yield of usable cycles. The batteries should also never be stored at a fully discharged state, and should always be charged using only manufacturer approved NiZn chargers.
I am not aware of any "monthly maintenance" requirement, but the NiZn batteries will perform better when they are charged more frequently than not, in other words, they do not like to be fully drained before charging.
I have attached some datasheet information that you might find helpful. If this did not answer your questions please let me know.
Gail
Customer Service
So, knowing this and that someone else on this forum I believe, that tested the cells at rates of something like, 1A, 2A, 5A, 10A, 20A (May be missing one)... They seemed to test fine at 10A, but he killed the cell when trying to test for 20A, even though I originally read they should be safe up to rates of 50C. Lol, sorry... I'm a data nerd. My point is the Ni-Zn curves look less consistant after the 1st 6 or so cycles and
I was wondering if they were held to the same 0.8v discharge cutt-off of the Ni-MH? I'm sure this a request among many and I'm so sorry to trouble you, but I'm just wondering if this is what to expect from the Ni-Zn at higher amperage rates, or if they cell's capacity and discharge characteristics were diminished by over-discharge?
Any info [and especially a retest with a fresh cell and a higher voltage cutt-off
] would be greatly appreciated!
Joe
