Hi,
i have now finished my custom mini chimera. here is the old thread where i start my tests with the sst-90inside the body: http://www.candlepowerforums.com/vb/showthread.php?t=253896
i get a raw body from brian so i done my own work on it:
Some technical Details:
Carbon cover
powder coated body
selfgrindet ucl lens
D2Flex PWM Driver from George
1000mA/h Lipoly Battery (need some work on the body to fit)
SST-90 with highest available bin (i am waiting for some neutral whites)
Blu Ray Laser ?mW (i ordered a green one from DX but they delivered me a Blue Ray laser so i put this in)
Micro-SD Card reader (also from dx) with a 16GByte Card as piggy-pack
2 on/off push bottons with permanent blue glowing led´s (i had them from broken fujitsu notbook docking stations)
2 red osram rebel on the side of the sst-90 also permanent glowing
2 blue trits on the right and left side
current for the permanent glowing of the push bottons and the rebells are 800µA
The light draws 3 amps at the highest mode. it will get hot after 30 seconds. in mode 5 from 8 it draw 1200mA and will be able to run continious without getting to hot - also extreme bright.
i never build such a light again. it was a hard work and very complex cause the space inside is very limited for all the electronics and the buttons.
markus
Carbon cover
powder coated body
markus
