trailhunter
- Joined
- Jul 2, 2014
- Messages
- 1,095
Looks like a chile tepin
Sent from my SM-G970U using Tapatalk
That’s what I thought but he said it doesn’t look like it. Whatever it is id like to eat it haha
Only other small round red pepper I know that looks like that is a cascabel. Look up that or “rattle pepper” and see if that’s it.
Heat is to the Audril UI light as like alcohol is to me. Alcohol made me think I was cooler than I really was.If anyone has a light with the newer Audril UI and feels it step down too fast here is what you do:
- Heat up light really hot with a hair dryer or a heat gun
- From OFF do 10 press for shortcut to thermal setting
- Light will blink out voltage slowly, When light does fast blink click 10 times
- Wait for slow blink to end and when fast blink resumes click 35 times
- This should fool the thermal sensor to thinking the light is cooler than it is
Has anyone experienced an Audril UI light that turns on when ever the battery is connected? I have a D18vn that turns on whenever the battery tube is screwed on and can't be turned off unless the battery tube is unscrewed. I suspect this isn't a UI issue but thought I'd throw it out there to people with more Audril experience. I'll probably have to send the light to Vinh, if it's a switch issue.
Got the light today and found 4 solder balls when I took out the driver. I think these shorted out the circuit. I only did LED swapped on D18vn so I never get to see the Driver unless it needs work.
Put in new driver and all works as it should![]()
My original E07 still does this, it comes on in moonlight mode and thats it until you unscrew/rescrew, then it does it all over again which would be perfect if i only wanted that mode...Got the light today and found 4 solder balls when I took out the driver. I think these shorted out the circuit. I only did LED swapped on D18vn so I never get to see the Driver unless it needs work.
And most of my orders have two lights!
I don't know if you covered this last time SkyLumen biz facts were discussed, but do you know about how many lights you have hand your hands in at this point? Has to be over 10,000, but may even be as high as 20,000.
Pretty good numbers considering you are essentially customizing every single order, on a 1-by-1 basis!
I am not sure how many light I have modded total but I started in 2008 which is ~ 8years before SkyLumen.com started
I can't believe I have been working on lights for 11 years now!
